Do you love flip fpv 250s mini drone?
drone fpv
#1 CNHL
CNHL
  • Пол:Женщина
Отправлено 23 Dec 2022 - 09:51
The flip FPV 250 mini drone is a popular choice for many drone enthusiasts. It's small, lightweight and easy to fly, making it perfect for beginners and experienced pilots alike. But what makes the FPV 250 so special? Let's take a look at some of its best features.
61M9mLYtJ6L._AC_SX679_600x600.jpg?v=1671
  • This 250 frame is made of 3K carbon fiber
  • Plenty of space to easily fit your FPV and neatly tuck away all the wires.
  • Equipped with rubber damper to reduce jello effect during flight.
  • Perfect combination with Emax MT2204, simon 12A ESC, CC3D flight controller, 6045 propeller
Flip fpv 250s mini drone
Flip fpv 250s mini drone is definitely one of the coolest drones that you can find in the market. It has a sleek and modern design that will surely turn heads. Not to mention, it is also very easy to use and operate. In fact, even if you are a first time user, you will be able to fly it with ease.
After you assemble a 250 size FPV that you like very much, you must be eager to try and fly. In order for it to take off and flip smoothly, you must be thinking, which brand and model of battery do I need to make it take off and land safely?
There are many cheap batteries on the market, and their performance is very unstable. I believe you have seen a lot of videos of FPV blowing up, and you definitely don’t want your 250s FPV to blow up. More and more FPV pilots began to recommend their friends to use CNHL's FPV batteries. Eight out of every ten FPV pilots use CNHL's FPV lipo battery. CNHL MiniStar 1500mAh 22.2V 6S 120C Lipo Battery must be your best choice for 250s mini drone FPV.
76CEF82F-7768-4042-971E-849905CDD0C8_600
Characteristic of 1500mah lipo battery
This 1500mAh lipo battery provides plenty of power and is able to handle the demands of flying a mini drone. Additionally, this battery is very lightweight and will not add much weight to your drone.CNHL 1500mAh 22.2V 6S 120C Lipo Battery has the advantages of long cycle life, cell voltage balance, low IR, high C burst discharge, etc. Most importantly, it has a very high cost performance.
If you are interested in 1500mah 6s lipo battery, welcome to contact 1500mah  6s lipo battery online store CNHL to read more.
#2 Bil
Отправлено 23 Dec 2022 - 23:47
Будут ли скидки покупателям нашего форума?
Темы с аналогичным тегами drone, fpv
